Tout sur les papillons
Mad
Message par Mad »
Voici un topic "récap" sur les papillons.
Je le mettrais à jour au fur et à mesure des infos données /trouvées donc n'hésitez pas à commenter !
Pièces pour moteur sporting :
Papillon 30mm : origine
Papillon 32mm : fire 1.2 8s 60cv (punto 1 60, ...)
Papillon 38mm : fire 1.2 8s mpi 75cv+ (punto 1 75, palio 75...)
Papillon 40 et 43mm : papillon de 38 réusiné avec un volet en 40 ou 43
Mount a écrit :Donc un papillon de 40mm donne 10% de puissance en plus sur un 1.1 comparé au papillon de 32mm d'origine
Augmentation du couple de 10 Nm
et de la puissance de 6-7cv
Le gars au danemark propose aussi un papillon de 43mm usiné à partir du papillon de 38mm mais pas de chiffres annoncés du gain
J'ai lu en diagonale mais j'ai compris qu'il fallait lui envoyer son papillon
Tricker a écrit :Hello
My name is Tricker
I write to you because I have a small business going in Denmark who makes the original throttle body bigger for Cinq/Sei. and Punto 55/60/75 mrk.1.
Maybe you already know that the 32mm throttle body form Punto 60 fits on the original intake on Cinq./Sei. but what you don’t know is that the original throttle body can be enlarged to 40mm witch matches the whole I the inlet manifold on Cinq/Sei. and Punto 55/60.
The Punto 75 can be 43mm
This 40mm throttle body gives the standard FIRE engine 10% more power
I have made some tests on rolling roads to have the exact numbers of the power gain.
The tests have shown a big different in the torque witch rises 10 Nm.
The power in high revs rises with 6-7 Hp.
Here’s a pic. of the original throttle body witch has bin rebuild by me - please note that the original butterfly lies on top of the new and bigger butterfly to illustrate the bigger diameter of the throttle body.
This 40mm throttle body is 80% bigger than standard
These two pic. shows the before/after printout from a rolling road test made on a standard Seicento 1.1.
The test is made on same roling road and the only changes were a 40mm throttle body.
The work I do with the throttle body is unique and contains a complete rebuild of the original throttle body.
With the enlarged throttle body comes a new and bigger spacer in aluminium and new gaskets – in short: you won’t need to buy anything else to fit the throttle body on the car.
It work this way: you send me a spare throttle body and I rebuild it here in Denmark - the p&p to Denmark and back to you will take 7-10 days in all.
The price of one rebuild throttle body and spacer-kit is 120 euro + 30 euro in post charge from Denmark to you.
The money has to be sent in Traveller Cheques with the throttle body written in my name.
Note: the post charge will be cheaper if you send more throttle bodies at the same time…
I have already made 40mm throttle bodies for some people on fiatforum.com and the respond has bin very positive.
Here in Denmark I have done a lot of throttle bodies for Fiat owners and every one have the same positive respond – more torque and extra power in high revs. The car is more alive after 100 km/h. and the top speed rise form 160-170 km/h. to 180-190 km/h.
I hope this mail makes you interested in getting a 40mm throttle body.
If you have any questions regarding the enlarged throttle body you can contact me on tricker_@hotmail.com
I’m also a happy owner of a Cinquecento 96’ and a member of two Danish Fiat clubs
www.cinquecento-fun-club.dk
www.fiatklubdanmark.dk
My Cinq.
My hobby is to tune cars and this is where I got the idea to enlarge the original throttle body.
My own car is running with a Punto 60 1242 engine witch deliver nearly 75 Hp. and 115 Nm.
I hope this e-mail will be taken as an offer to all Cinq/Sei. and Punto 55/60/75 owners in your club.
Thanks
Regards from Tricker in Denmark
sur un autre topic il détaille sa prépa qui avait évolé, assez intéréssant le résultat
bloc 1242 8s 60cv
papillon usiné (40)
ligne supersprint
collecteur d'admission plus gros
arbre à cames Colombo & Bariani 280°
110,7 Nm / 4916 rpm.
95.0 Hp. / 6552 rpm.
Tuto de changement de pap' + infos :
Nos a écrit :Voilà un petit post qui devrait en interesser plus d'un ...
Aujourd'hui, nous allons parler de respiration.
Comme vous le savez, votre moteur a besoin d'air pour fonctionner, et plus il y en a, mieux c'est (à condition toutefois que ça sorte aussi vite que ça entre .. et vice-versa).
Mercredi, avec mon Ami Benny, nosu avions projeté de monter la MPI sur ma Cinqué. Mais il manque un connecteur spécial pour l'arrivée d'essence. Donc, comme on ne joue pas avec la securité quand on s'appelle Ben38 et que l'essence ça brule (oui, comme le feu :) ), on s'est "rabattu" sur un simple changement de Papillon ... Quand je dis rabattu avec des guillemets, c'est ironique, vous comprendrez ensuite.
Donc c'est parti.
Là, c'est mon moteur : vous voyez déjà que je profite d'une admission de punto avec un gros couvercle d'admission et une grosse durite.
On demonte, ici, le papillon d'origine (diamètre 30, ah ah ah) à nu.
Il faut tout debrancher et vider le liquide de refroidissement. Prevoir une vis pour boucher la durite d'arrivée d'essence.
Un enlève le petit boitier de papillon, et on remonte le nouveau me direz-vous !! et bien non, bande de nazes :D !!!
Regardez ici, l'entrée du collecteur d'admission :
un trou de 38, comme notre nouveau boitier papillon .... mais juste avant le collecteur, il y a une pu**** de cale rouge avec un trou de 30 ..... donc si on laisse comme ça, ça ne sert à rien !!!
Bon, pour la suite, il faut du materiel de haute technologie :
oui, je sais, j'abuse, mais c'est ce genre de truc qui vous permettra de ré-aléser la cale à 38, pour avoir un conduit qui fait 38 tout du long !
Voilà la cale modifiée avec un trou de 38 :
Bon, cette fois, on remonte.
On rebranche tout, on remet le liquide de ref .... et on AUGMENTE la pression d'essence, sinon ça demarrera même pas !!
Ensuite ça demarre. Il faut regler la pression d'essence avec un materiel de haute technologie : un Ben38 :)
Et ensuite, c'est que du bonheur à conduire, le gain est vraiment REEL, j'ai le sentiment d'avoir une nouvelle caisse :) !!!
Elle tourne comme une horloge, adore flirter avec la zone rouge (pas comme avant), tout en restant très souple avec du couple en bas.
Voilà, je vais passer la parole à Benito pour compléter mon exposé :)
Et encore une fois : Merci Benoit :)
Dernière modification par Mad le mer. 16 mars 2011 20:46, modifié 1 fois.
Timo387
Re: Tout sur les papillons
Message par Timo387 »
Bonne idée ça : )
Par contre je pense qu'au lieu de mettre un lien vers l'ancien forum, il serait préférable de carrément intégrer le texte sous forme de citation et en mentionnant les auteurs respectifs.
Tout cela de manière à concentrer les infos sur ce forum, mais aussi de manière à ne pas perdre les infos lorsque l'ancien forum ne sera plus en ligne ; )
_____________________________________________________________
Fiat Cinquecento Abarth (1994)
Fiat Stilo JTD 115 (2001)
Type de Cento : en sevrage
Message par Joalfa »
Tout à fait messieur !! :D
Mad
Message par Mad »
Timo387 a écrit :Bonne idée ça : )
Tout à fait d'accord ;)
Pour cela il faudra pouvoir choper le bbcode direct sur l'ancien forum mais comme il est fermé... :(
Timo387
Jo' ou thomate doivent encore y avoir accès je suppose, je pense qu'il vont pouvoir te donner le code : )
Je me trompe ?
Tout à fait ! :D
Je m'en occupe ce soir.
Mad, je t'envoie par MP le code dans la soirée.
Jo ;)
Mad
Message par Mad »
Super cool merci ;)
MP envoyé. ;)
Mad
Message par Mad »
It's ok ;)
Timo387
Impec' ça ! : )
nikel ! 8-)
Timo387
Quelqu'un a déjà fait la modif' d'agrandir le corps papillon de 38 jusqu'à atteindre un diamètre de 43mm ?
Si c'est trouvable, sur quel modèle peut on trouver un volet de 43mm ?
Mad
Message par Mad »
timeless a écrit :Salut j'ai fini par trouver un pap en 43mm pour utiliser le volet:
Mazda 323 1.3 73cv 1994-1998
Timo387
Excellent merci : )
Par contre ça doit être la misère pour trouver, je vais regarder ça ; )
Mad
Message par Mad »
Sinon sur quad, j'en ai trouvé facilement ;) moteur 450
Mad a écrit :Sinon sur quad, j'en ai trouvé facilement ;) moteur 450
Sur quad...??? C'est à dire?
Sinon sa peut se trouver ou?
Pareil que l'AAC casse ou voiture en pièces sur le bon coin. ;)
Après celui du quad.... j'en sais rien ! :D
Mais ça me tente de plus en plus de passer a 43... :roll:
Mad
Message par Mad »
On en veut toujours + !! :D
@Neness : un volet de papillon, c'est rien d'autre qu'une disque métalique avec une fixation pour mettre un axe qui le tient... donc qu'il vienne d'une voiture ou d'un quad, le résultat est le même.
Timo387
Pareil, dès que j'ai un peu de temps je m'y met ; )
Mad
Message par Mad »
Et le pap' de punto 2 1.2 sporting ? ca passerait pas ?
Tiens moi au courant du schumlbilk Timo ! ;)
Moi par la suite, ont va commencer avec un pap 38, histoire de voir la différence.
Tu la ressens de suite, et à la pompe aussi ! :D
Joalfa a écrit :Tu la ressens de suite, et à la pompe aussi ! :D
Oui mais le plaisir n'a pas de prix, surtout pour un newbee :D
Tu pourra essayer la mienne si tu veux, tu verra la différence avec ta noir. ;)
Pas de soucis, c'est avec plaisir pour monté dans un poussin :mrgreen:
Timo387
Joalfa a écrit :Tiens moi au courant du schumlbilk Timo ! ;)
Pas de soucis, je ferai quelques photos ; )
Oui pour les photos et quelques explication si c'est possible :roll:
Mad
Message par Mad »
Voici des infos pour un papillon réallésé :
Des photos du pap' :
retrorides.proboards.com a écrit : Same thing with the throttle body, there were resleeved 40mm TBs for sale at the time but they were strong money (rightly so, due to the machining) whereas the 75 38mm was £15 off ebay and only needed an afternoon sat in the sun in the garden with the dremmel to reshape to fit the SPI top piece and port the inlet manifold and spacer to match. Another evening was spent with the dremmel matching the manifolds to the head, every little helps, especially when the kerbweight's so low.
Google trad mon ami a écrit : Même chose avec le corps de papillon, il y avait resleeved 40mm SCT pour la vente à l'époque, mais ils étaient monnaie forte (à juste titre, en raison de l'usinage), tandis que les 75 38mm était de 15 en dehors d'eBay, et seulement besoin d'un après-midi, assis au soleil dans le jardin avec le dremmel à remodeler pour s'adapter à la SPI partie supérieure et le port du collecteur d'admission et l'entretoise de match. Une autre soirée a été consacrée à la dremmel correspondant aux variétés à la tête, chaque petit geste, en particulier lorsque le kerbweight est si faible.
Vu la gueule qu'il a... ça va etre chaud de faire + que 43mm. Déjà 40 ça a l'air bien fat.
Sur les photos on dirait que 40mm c'est le grand max... :shock:
Mad
Message par Mad »
En fait, en haut il est travaillé en forme d'entonoir (c'est pas con d'ailleurs) du coup, en haut il n'est pas à 40 mais au niveau du pap' si ;)
Pourquoi en entonnoir, sa change quoi?
Mad
Message par Mad »
pour plusieurs raisons :
- le rétrécissement progressif donne un effet venturi, ce qui augmente la vitesse des gaz au niveau du volet
- il n'y a pas de "marche" qui cassent le flux d'air, on est sur des changements de directions + doux avec des arrondis au lieu d'angles.
En règle générale, dans tout ce qui admission et échappement, enfin partout ou il y a des flux d'airs avec un bon débit, il faut éviter toute cassure, tout angle.
Plus le circuit est fluide, moins l'air sera ralenti, + il y en aura dans le moteur, + on aura de puissance / couple.
Mad
Message par Mad »
Exemple :
Uploaded with ImageShack.us
Celui de gauche est bien moins efficace que celui de droite.
P'tain c'est mortel ça !!! :o
Sur la 2eme photo il est vraiment, limite, mais effectivement, le 1er en "entonnoir" est top !!
ça donne à réfléchir.... :roll:
Mad
Message par Mad »
Joalfa a écrit :P'tain c'est mortel ça !!! :o
C'est le meme pap' ;)
Pense a ta futur conso :lol: :lol:
Je pense que 38 c'est déjà bien ;)
Mad: Super taff, sa doit etre doux comme une peau de bébé :mrgreen:
Une fois montée, tu nous dira ce que sa donne par rapport au 38
Mad
Message par Mad »
Ce n'est pas à moi, c'est du trouvé sur le net, j'écris pas anglais moi...
Puis tu sais, entre un 38 et un 38 "entonnoir", y a presque zéro différence de conso...
Mais par contre il y a des réglages à faire. :D
Question concernant les papillons pour les connaisseurs.
J'ai trouvé une annonce pour un papillon de punto 1.2 16s 80ch (45€ fdp in), est ce qu'il ce monte sur nos cinqué?
je ne pense pas qu'il monte . a moin de regarder sur un bloc de punto 75 si avec l' injection multipoints il y aurai possibilité de le monter avec une calle d'adaptation.
en tout cas attention au modele de punto 16v sur lequel il provient car tu a 2 modele !!! celui qui est tout electrique et celui ou tu a la commande du papillon avec un cable ( comme sur la cinqué quoi)
sela depend du diametre du papillon( honte a moi je possede un 16 et je ne connais meme pas le diametre du^papillon. )
OK, au vue de tes explications je pense que je vais attendre d'en trouver un autre ;)
Sinon les papillons possible(plug and play), c'est celui de punto 1.2 8s 75ch, c'est sa?
ouais pour le papillon de 75 ch mais pour les adaptation mineure qu'il faut faire je peu pas t'aider !! faut voir avec les membre qu'il l'ont fait. joalfa par exemple !!
OK, merci je vais voir avec Jo pour avoir un peut plus de détailles. Merci encore ;)
Mad
Message par Mad »
punto 1 ou palio 1.2 75cv
OK, j'ai compris je vais chercher ça dès demain ;)
c'est plug and play !
J'ai entendu une histoire de cale qu'il faut agrandir, mais moi, j'ai enlever le petit pap, mais le gros et basta, ca ouiiiinnneee!!!!! :D
Joalfa a écrit :c'est plug and play !
Quand j'aurais tout ce qu'il faut (cinqué compris :lol:) j'aurais besoin d'un petit coup de main si c'est pas de refus :roll: ;)
Timo387
Sur une cinqué d'origine l''entrée du collecteur d'admi est en 38, la cale en 30 et le pap en 30. Quand tu montes le pap' de 38 il faut usiner la cale qu'il y a entre le collecteur d'admi et le pap' de 38, sinon ça ne sert pas à grand chose
-> 38 / 30 / 38 ...
Dernière modification par Timo387 le ven. 1 avr. 2011 20:21, modifié 4 fois.
mais moi j'ai pas vu de cale... :x
c'est la petite entretoise en plastique noir situé sous le papillon d'origine . ( si j'avais une photo qui traine je te montrerai )
je vais démonter pour regarder. ;)
Toutes façon, il va pas rester sur le moteur ! ;) :roll:
Timo387
Bizarre ça XD
Joalfa a écrit :je vais démonter pour regarder. ;)
Pourquoi, tu vas l'enlever?
oui, je vais le virer, pour vérifier la cale. ;)
Ah OK ;)
mica18
Type de Cento : cinqwé et seicento
Message par mica18 »
une ptite question jo, tu as bouger au reglage de la vis de pression d'essence ou tu as juste mis le papillon de38 avec ton monopoint sans rien changer?
perso, j'arrive pas à avoir le bon mélange air-essence...si quelqu'un peu m'aider à ce sujet???!!!!
j'ai remis mon papillon de 30 avec mon autre monopoint dessus reglage origine.
j'ai une boite à air origine avec k&n dedans et devant de boite à air découper + trous dans la fausse calandre...
elle est petite mais elle a tout d'une grande...
Timo387
mica18 a écrit :une ptite question jo, tu as bouger au reglage de la vis de pression d'essence ou tu as juste mis le papillon de38 avec ton monopoint sans rien changer?
Oui il faut modifier le réglage de la pression d'essence.
De mémoire, le point de référence c'est d'augmenter (visser) la pression d'essence de 2 tours et demi par rapport à l'origine.
Ensuite tu affines en regardant la couleur des bougies ; )
Merci pour les précision Timo ;)
Timo387
Pas de soucis, avec plaisirs =P
mica18
merci pour vos réponses ;-)
Voila Mica ! :D
désolé à la bourre sur tous les posts.... :?
Mad
Message par Mad »
J'ai reçu mon pap38 xD
Cherchez l'erreur :lol:
Voici comment je l'ai reçu, c'est un pap' complet de punto 75.
Et voila après démontage / nettoyage :
salut, c'est cool ;)
Par contre c'est quoi la cale en haut a droite avec un tube coudé? :|
Mad
Message par Mad »
Aucune idée mais je dirais liaison vanne EGR ou un truc du genre.
Ah moi je l'ai pas ce truc :lol:, mais tout le reste oui ;)
fred.595
Message par fred.595 »
Si j'ai bien tout compris, le papillon d'origine de la Cinque Sporting (30 mm) peut être réalésé jusqu'à 40 mm :?:
C'est bien cela ou je me trompe :?:
Mad
Message par Mad »
Tu as mal lu ;)
Le plus simple est de prendre un pap' de 38 (origine punto 75 ou palio 75...) ;)
Après tu peux le faire réaléser à 40 voir meme 43 (en changeant bien sur le volet).
Will-Hunter
Message par Will-Hunter »
fred.595 a écrit :Bonjour,
Une Présentation n'est pas une option, mais une obligation, c'est pas compliqué, on est pas un forum de va et vien avec que des membres fantômes, on s'inscrit, on se présente et ensuite on pose les questions, c'est le respect mutuel, même si c'est pour un passage éclaire ! Ici on est des passionnés qui se feront un plaisir de t'aider et de répondre a toutes tes questions, mais on attend un minimum de chacun. Merci
Désolé je suis pas modo mais ça m'énerve :evil:
fred.595
Bonjour MONSIEUR Will-Hunter,
Merci de ranger au vestiaire votre Pitbull.
Question respect, la forme de votre intervention n'en est pas une.
Il est vrai que je ne me suis pas re-présenté lors de l'ouverture de ce forum, l'ayant déjà fait avant vous sur l'ancien. Je n'ai pas pensé que cela était obligatoire, et l'ignoble microbe que je suis vous présente ses plus plates excuses. Je vais le faire, mais je pense qu'il y a d'autres manières de le faire remarquer qu'en chassant sauvagement après le forumeur isolé.
Je vous prie d'agréer mon cher Monsieur, l'expression de mes salutations les plus respectueuses.
Will-Hunter
Désolé si j'ai pu vous vexé mais mon intervention n'était pas méchante en vers vous particulièrement mais une intervention plutôt énervé certes mais envers tous ses membres fantômes qui viennent pour créer je ne sait combien de sujet pour une question et qu'on ne revoie plus après, cela ne fait que gâcher le forum, n'est en moins que je suis heureux que des anciens reviennent sur le nouveau forum et je te dit donc la bienvenue et m'excuse a mon tour.
Message par Fab93 »
@fred.59 : tout le monde passe par la case présentation, même les plus anciens voire l'initiateur de l'ancien forum ! ;)
fred.595
Will-Hunter a écrit :Désolé si j'ai pu vous vexé mais mon intervention n'était pas méchante en vers vous particulièrement mais une intervention plutôt énervé certes mais envers tous ses membres fantômes qui viennent pour créer je ne sait combien de sujet pour une question et qu'on ne revoie plus après, cela ne fait que gâcher le forum, n'est en moins que je suis heureux que des anciens reviennent sur le nouveau forum et je te dit donc la bienvenue et m'excuse a mon tour.
Pas de problème, l'incident est clos et ... je suis allé me présenter 8-)
Mad
Message par Mad »
De toute façon, la création de ce nouveau forum est pour moi une véritable erreur. Cela pose + de problème que cela n'en résoud. D'autant qu'objectif était de regrouper les 600, "communauté" carrément inexistante... et sans réel motivation de la part des membres j'ai l'impression.
Bref, les anciens qui s'inscrivent ne savent pas quoi faire, on recopie les infos qu'il y avait déjà... bref... je suis pas le seul à me demander pourquoi tout à changer...
fred.595
Mad a écrit :Tu as mal lu ;)
Le pb est que par ici, il n'y en a pas dans les casses. Soit du Punto 60 car plus répandue dans la région ou alors autos déjà passées dans le broyeur (prime à la casse oblige) Un génocide de Palio dans l'usine de déconstruction automobile proche de Douai ;)
Alors comme j'ai un papillon d'avance de Sporting en 30 mm et un papillon d'un Weber 40 dans mes pièces, je me demandait si techniquement il était possible de réaléser le corps de celui de la Sporting: assez de matière?
Dans la réponse faite par le préparateur Danois, j'avais compris que c'était faisable.
fred.595
Je me réponds à moi même.
J'ai déposé le papillon de la cinquet' cet après midi.
Pas assez de matière pour réaléser au delà de 34 mm. Cela n'en vaut pas la peine.
Bon, vais me mettre en chasse pour un 38 mm.
Mad
Message par Mad »
Si tu veux, je te vends le mien. Je l'ai acheté en prévision d'une future cinque... et je sais pas quand ça sera... par MP si tu es interessé.
La chasse ne fut pas longue :lol: ;)
fred.595
J'ai trouvé mon bonheur :P
Un papillon de Punto 75 + la culasse avec l'AAC à 35 bornes de chez moi.
Le gars prensait vendre des pièces de 60.
Il ne me manque plus qu'une "bonne puce" et l'échappement.
Merci à Mad pour s'être proposé en // 8-)
Will-Hunter
Ah c'est cool ça, elle va avoir du caractère la titine, manque la ptite ligne Gr N ;-)
Si il a encore l'admission prend là ;)
fred.595
La pipe d'admission fait partie du lot, mais il n'y a pas la rampe d'injecteurs.
OK ;)
GTi-Access
Message par GTi-Access »
Pour passer en multipoint on change obligatoirement la culasse?
Forum auto sportive
non pas besoin tu change juste ta pipe d'admission et tu modifie ton faisceau d'injecteur d'origine !! ;)
GTi-Access
Ok donc le MPi c'est pas une injection direct
Forum auto sportive
non ! meme le 1.2 16v et le 1.4 turbo 16 de la abarth on l'injection sur la pipe !!
GTi-Access
Et le MPi des seicento après 2000
ca ce monte sans rien changer d'autre que la pipe?
Il y a pas d'autre capteur...
Et les new panda 1.1 mpi c'est pareil?
Forum auto sportive
Mad
Message par Mad »
Si ça interesse qqun, je vends mon pap38...
Je l'avais acheté en prévision d'un achat de cinqwé mais finalement, ça tombe à l'eau (en tout cas pour les 6 mois à venir) donc... si ça interesse qqun, me contacter par MP !
GTi-Access
Mad pour la piece dont tu te demandais ce que c'était, le sorcier qui m'a aidé à la monter et moi on pense que l'auto était monté GPL. Tu en penses quoi???
Forum auto sportive
Mad
Message par Mad »
C'est possible en effet. Mais je sais vraiment pas, je ne me suis jamais interessé aux instal GPL.
En tout cas, cette pièce pourrait servir à un truc sympa : injection de protoxyde d'azote
Message par titof53 »
bsr,a y est pap 38 monté,(sacré différence sa pousse réel) par contre au niveau de la cale de diam 30 a agrandir (drole de matière),j'ai préférer m'attaquer a celle
du palio au bon diam 38 inter(en alu) que j'ai eu avec ce pap, mais plus haut de 2cm!!.
Alors,au programme,découpage de la colerette a la meuleuse,surfacage ,polissage inter.
decoupe de la collerete (palio a gauche cinqué a droite)
(120.31 Kio) Téléchargé 46604 fois
surfacage
surfacage
final
final
Joli boulot, t'as dû y passer du temps ? :roll:
Oui,effectivement,sa fait 2 jour que je paufine tout sa ;) aller j'ai encore droit a 3 fichiers a envoyer!!!!! photos
palio 38 vs cinqué 30
(120.11 Kio) Téléchargé 46600 fois
mise en place avec joint neuf +nouvelle tige plus 2cm oblige
(129.69 Kio) Téléchargé 46600 fois
GTi-Access
Tu as tout monté? La boite a air touche pas le capot
Forum auto sportive
Bjr,pour ta question,oui j'ai tout monter sa passe nickel avec la cloche de palio! meme sans l'isolant capot que j'avais viré avant,a vue d'oeil capot déclavé y'a une bonne marge sans soucis!!
(152.19 Kio) Téléchargé 46570 fois
GTi-Access
Ok ta pas essayé avec l'origine. Je pense que ca touche.
Forum auto sportive
Non pas essayer,mais j'penserai comme toi,quoique sans l'iso capot!!,a voir, je ferait le test on verra!
Message par Hum91 »
Jolie montage... ton 4 cylindre doit bien respire maintenant !!!! ;) ;)
Assez satisfaisant c'est vrai!! elle prend l'air a pleins poumons et des bonnes montées en tours minutes.
Quand a ma cale de palio retravaillé,heureux que sa marche,sa pourra servir pour des futures montages!!
